Motion sector
Can the motion detection light on the cameras be turned off so people can't see it iluminated? Thanks
Message 1 of 2
1,557
Cooper22 wrote:Can the motion detection light on the cameras be turned off so people can't see it iluminated? Thanks
If your referring to the IR illuminators ( that provide vision for dark ) ... the IR uses 850nm range and that is slightly visable to the normal eye ( glows slighty red ) when on.
But they can be toggled OFF. This gives less vision in the dark but if you have regular outside lighting that may be enough.
Message 2 of 2
1,537
Android App
Geo-Fencing
89 -
iOS App
Online Web
Surveillance
