Motion on one camera, record on all cameras
  • 2 Replies
  • 2446 Views
diirekt
When motion is detected on one camera I want to record on all my cameras. How do I?
JPC
Prodigy
Prodigy
Go to Settings-->Rules-->Click "Add" or "+" on the upper right corner and create your "Rules Definition"..
Here's an idea if you have 3-CAMS.. Label Name Example --> CAM-1, CAM-2, CAM-3
Rule-1:
CAM-1  Motion detects on "Cam-1" and Records on "Cam-1"   ---> Don't forget to click "SAVE" or "Done" on upper right corner
Rule-2:
CAM-1  Motion detects on "Cam-1" and Records on "Cam-2"   ---> Don't forget to click "SAVE" or "Done" on upper right corner
Rule-3:
CAM-1  Motion detects on "Cam-1" and Records on "Cam-3"   ---> Don't forget to click "SAVE" or "Done" on upper right corner
Rule-4:
CAM-2  Motion detects on "Cam-2" and Records on "Cam-2"   ---> Don't forget to click "SAVE" or "Done" on upper right corner
Rule-5:
CAM-2  Motion detects on "Cam-2" and Records on "Cam-3"   ---> Don't forget to click "SAVE" or "Done" on upper right corner
Rule-6:
CAM-2  Motion detects on "Cam-2" and Records on "Cam-1"   ---> Don't forget to click "SAVE"  or "Done" on upper right corner
Rule-7:
CAM-3  Motion detects on "Cam-3" and Records on "Cam-3"   ---> Don't forget to click "SAVE" or "Done" on upper right corner
Rule-8:
CAM-3  Motion detects on "Cam-3" and Records on "Cam-2"   ---> Don't forget to click "SAVE" or "Done" on upper right corner
Rule-9:
CAM-3 Motion detects on "Cam-3" and Records on "Cam-1"    ---> Don't forget to click "SAVE" or "Done" on upper right corner
Hope this helps..
Note: You'd have to test & play around with "Motion Sensitivity" and "Length of Record Time" to make sure that it's in the right delay or enough record time to capture the right moment of action..
JPC
Prodigy
Prodigy
Also, I believe Label Names must be unique:
Edit Example Above To:
Rule-1:
CAM-1
Rule-2:
CAM-1/2
Rule-3:
CAM-1/3  .. and so on...
