  • 1 Reply
  • 1857 Views
Turbo2
How do I just have certain cameras detect motion?
Turn on the mode ALL MOTION ACTIVE ( or similar named, don't remember the default name )
go to the live camera view screen
Check and see all the cameras SHOULD have a GREEN "running man" above each one.  GREEN rm means motion detect is on, GRAY it is off.
To make certain cameras active ( say 2 inside. 2 outside ) and you want ONLY OUTSIDE
Make a new MODE
Go to settings/modes , hit the ADD button
Name the new mode OUTSIDE MOTION
all you cameras are listed, toggle the check mark at the end of outdoor cams to GREEN ( means active ) all other should be black ( off )
Save
Start OUTSIDE MOTION mode, go to live view screen and you should see only the running men GREEN over the outside cams.
