  • 9 Replies
  • 3360 Views
bpatel23
I keep getting this motion detection error, not sure what is causing that and what it even means.
9 REPLIES 9
Need details.  What error, when, can you live view and manually record, etc.? Details.
bpatel23
Every time is senses motion, it will detect, record, and messages me via email: "Arlo has just detected motion error"
That's new.  Is there a video in the library?
bpatel23,
Are you able to live stream the camera and produce manual recordings? Also, if you could, please provide a screenshot of the error message.
bpatel23
seems like the message error comes only via the text/email and not the app itself.
bpatel23,
It almost sounds like this is the expected motion detection email alert. Within your rules there are two options to alert the user when motion is detected. Push notifications and email alerts, you can enable/disable these within the rules for each of your cameras.
If this is what you are describing, this isn't an error message. It is a motion detection alert indicating your cameras are sensing motion and producing recordings. If you do not want these alerts, they can be disabled. For more information on how to disable the alerts, see here: How do I turn on/off email notifications?
bpatel23
Thank you for your responses. These email/text alerts are happening only when motion is detected which is fine. I am just confused of why it says "motion detection error". Strange why it would send me that message vs. the message I receive via push notification says "motion detected."
bpatel23,
Do you still receive the email after disabling email alerts? A screenshot to show the exact verbiage of the email would help determine if this is expected behavior or not.
bpatel23
Error is just a function of the way the text message comes across through sprint text to email function. The push notification does not show the error. I think everything is working fine. Thanks.
