Mode Setup
  • 1 Reply
  • 1451 Views
pallavk3
I installed 4 Arlo Pro cameras, I am trying to setup 2 cameras that are placed outside the house on Arm mode so they detect motion and send push notification 24/7, the indoor cameras need to be armed only when required. How can I setup zones so I can control arming and disarming seperately.
Don't confused zones with modes....
Arlo PRO cameras do't do zones like the Q cameras, but they will do Modes.
What you need to do is break up the default ARMED ( all on ) into two custom modes , inside and outside , so you can pick from all cams, inside cams and outside cams.
You need to CREATE a NEW MODE;
https://community.netgear.com/t5/Arlo-Knowledge-Base/How-do-I-create-a-new-mode-for-my-Arlo-Q-and-Ar...
Once you start and set up a new mode, go back and edit it to add the second camera
So, you should end up with, ARMED (all on), INSIDE (inside only ),OUTSIDE (outsie only), DISARMED ( all off )
TIPS;
Only one mode can run at a time
Any camera NOT in the active mode is off
