Mobile App: Poor Usability of "Camera Pan/Zoom" settings
  • 1 Reply
  • 559 Views
hshi
On Mobile App (both Android and iOS) the "Camera Pan/Zoom" setting is difficult to use.
User needs to use a finger to drag the corners of the Pan/Zoom rectangle on touchscreen, however due to display bezel, it is impossible to reach the outermost 5-10 pixels.
Suggest a magnifier popup showing the precise location of the Pan/Zoom rectangle.
You can always drag the selected area around to show the edges. Press in the middle of the area.
