Is there a way to do continous recording while there is motion?
  • 1 Reply
  • 2053 Views
ertert
Just set everything up and it appears to be working OK. I am aware the RECORDING TIME can be increased.
It seems even if there is movement I still only get a 10 sec recording.
Had a cam outside and a bunch of birds on the ground set it off. Got 6 10 sec recordings in about 10 minutes.
I can move around right in front of a cam and still get 10 sec and then it shuts off. Takes awile to come back on.
This is kind of defeating the purpose. If some body is trying to break in my back door I will only get a 10 sec recording.
Once activated it should keep going while there is  movement.
I realy don't want to crank up the time to maximum because that is a waste.
No, continous recording while motion continues is not possible.
It will record for the set time and stop.. if motion continues after a few seconds it will start a second timed record session
