Is it possible to use Geofencing Mode
  • 8 Replies
  • 5951 Views
AntonioG
just for some cameras not for all my cameras connected to the station?
I have arlo pro with a android system
AntonioG
Within Geofencing settings, set "Away" to the default "Armed" mode and "Home" to a custom mode that has rules for all cameras to trigger on motion except the inside camera.
This results in all cameras recording motion (including the inside camera) when you are "Away" and when you are "Home", all cameras except the one with no rules (inside camera) will record on motion.
I hope this helps.
8 REPLIES 8
Yes, by creating a custom mode with only the cameras needed.....in geozone
Of course any cameras not in the active mode is off.
OR... if you use a second base, you could run two separate modes at the same time with only one base on Geozone
AntonioG
But how do you add geofencing to the new custom mode?
I added a new mode and it doesn't show me any options to add geofencing to it, and if I go to existing geofencing and try to modify it doesn't let me select the cameras I want to use in this mode
Sorry , maybe wasn't clear
It's the other way around, you pick the Mode to use in Geozone
In android... you pick Geozone to edit
on next screen AWAY MODE usu is Armed, but if you tap that line, you can pick any of the modes you have.
Pick your custom mode, click done
It goes back to previous page, SAVE
Now you AWAY MODE is a custom mode
remember , any cameras NOT in the active/custom mode are off
Schedule and Geozone aren't really modes, but sub routines that turn on/off modes you have ( be default or custom )
AntonioG
Now I get, thank you very much... Now let me explain what I'm trying to do, I have 3 cameras outside around the house and one inside the house pointing at the main door. I would like to have the one inside to be on Geofencing and the other 3 armed all the time. Is this possible?
It would be real easy with a second base unit  🙂
I'll have to think on this one... most things but not all are possible
Quickly tho,  it is easily done with 2 custom modes tho it would be manual... let the geo sink in here as I don't use it alot.  ( maybe others do and will help )
AntonioG
Thank you
AntonioG
I hope this helps.
AntonioG
You are a genius! You are right, I didn't know you can change to a custom mode when "Home"
Everything is set, now I'm I'll be testing the motion sensors when nobody home, just the dogs; but it seems like I'm set
Thank you TomMac and JamesC for helping me clear my mind and think outside the box
