  • 5 Replies
  • 39699 Views
2320Chester
The camera uses IR (heat differential) to capture motion.  It will "see" car engins, people, animals, etc.
In the past I had web cam software that actually detected any type of motion to begin recording.  If anything moved within range, it would be catured.
Does anyone know of a software that I can use with this system?
Not at this time - it's all proprietary.
5 REPLIES 5
<In the past I had web cam software that actually detected any type of motion to begin recording.  If anything moved within range, it would be catured.   >
that was more than likely a system that detected motion via change in the actual pixels ( of the camera view )
This system uses a IR sensor which is a PIR
2320Chester
These IR cams can not "see" through a window, for instance.
More specifically, the IR motion detection doesn't work through a window.
2320Chester
Yes, that's exactly what I said.  IR cams can't see through windows.  They work on heat differential vs pixel differential.  That's why I asked the question if anyone knew of a software that would (see through windows.)
