  • 5 Replies
  • 2109 Views
tjohnson147
I have 4 cameras......2 are inside cameras that i do not want motion on , i looked at the community answers and tried everything...the two cameras i have outside are in motion (thats what I want them to do) how do i turn off the cameras inside motion off. Its running the batteries down fast cause everytime we pass in front of it ...it begins recording. I just want the two cameras inside to stop motion (not go off to where i cant log in and see real time) .....
5 REPLIES 5
You need to create your own mode with appropriate rules to do this.  Go to thew Mode tab, select your base station and use the Add a mode button at the bottom. Follow the bouncing ball, selecting a camera that will be activated and whatever settings you choose.  Save.  Reedit that mode and add a new rule for a second camera, making similar settings.  Save.  Continue until any cameras that you want active are set up - if a camera doesn't have a rule, it will be disarmed.  Once done, select that mode to be active or set a schedule as you desire.
tjohnson147
u said log into mode and follow bouncing ball....there is no bouncing ball....it only has a thing that says name and a space to type something in....? Do i need to up date the arlo app on laptop or something?
LifeIncome
Doing as you suggest would one still be able to live view via ones smartphone the non-motion activated arlo's in the house?
The "bouncing ball" is a euphemism based on the old Mitch Miller TV show where a bouncing ball lead you through song lyrics.  There is no literal ball.
Once you're in the Mode tab, click on your base station.  That brings you to a screen where existing modes (likely just Armed and Disarmed) and the schedule are displayed.  Go forth and conquer.
And there is no app for a computer - it's just the web page.
Absolutely.
