  • 4 Replies
  • 2723 Views
phattrance
I own 3 Arlo cameras and i was wondering how i can add the 100% motion detection on the schedule settings? I cant find a way to add it there. When choosing a specific camera only, ill get a slider where i can choose the motion sensitivity but im not able to do that under the schedule settings. Am i doing something wrong here??
Yes... your thinking might be right but the answer is skewed...  :0
First, you can only have ONE mode active at a time, the mode consists of rules for each camera ( how long record, etc )...YOU CAN'T PICK A CAMERA FOR THE SCHEDULE, YOU PICK A MODE ( which contains the cameras you want to use )
The schedule does nothing more than turn a mode on/off at a given time.
SO, easiest is to ADD a new MODE, add the cameras you want with the settings you want ...THEN add that mode into the schedule
phattrance
The thing is that when i create a new mode (to connct to the schedule later) i can ONLY pick ONE camera, and not all three of them.  How do i pick several cameras on the same mode?
phattrance
i figured it out 🙂
In case others are following the thread....
Once you create a new MODE, go back and edit it to add the extra cameras.
