  • 4 Replies
  • 4059 Views
  • 2 Likes
67stang
Where in the newly released app 12-28-2105 do you set recording time and motion sensitivity for each camera?
Thank you
snip3rboy
You can edit your camera rule's sensitivity through Modes > Your Device > Edit Mode > Edit Rule > Click Edit Icon in Motion Sensitivity.
Click Edit Icon in Recording Duration to change the duration.
snip3rboy
Glenb
Are you sure this works. I followed your steps and upon pressing mode the only option I get is all device Id and all motion on
Glenb
I don't get the option of your device/edit mode etc
Glenb,
After you click mode and select the device id you should see all of your modes. Click the pencil icon for the mode you want to edit and you will then see a list of rules for that mode. Click the rule you want to edit and you will then see all options available for that rule. To change motion sensitivity click the pencil icon next to the "Detects Motion" option.
Take a look a this article that provides step by step instructions: How do I adjust motion and sound sensitivity?
