How do I create a new mode for my Arlo Q and Arlo Q Plus cameras?
Can you creat a custom mode that allows you to pick a subset of cameras and then schedule them by time? I see how i can setup the mode with rules but i have to arm it and turn it off each time but not how to schedule on / off by time.
Message 1 of 4
2,032
Yes. Use the schedule to select a mode and schedule the time you want it to be run. Just edit the schedule and check it out.
Message 2 of 4
2,023
But how do I select only a subset of cameras from the basestation cameras. I guess i wasnt clear. I have some inside and out. I only want the exterior ones to be on a set schedule.
Message 3 of 4
2,016
Create a new mode with rules for ONLY the cameras you want active. A camera with no rule is disarmed. Then place the specific rules in the proper times in the schedule.
Message 4 of 4
2,009
Android App
Geo-Fencing
89 -
iOS App
Online Web
Surveillance
