  • 11 Replies
  • 22443 Views
  • 4 Likes
  • 7 In Conversation
amattiel
Just purchased the Arlo Security! Awesome, easy to use and set up. Quick question, once motion is detected the recording is 10 sec. Is there a way to increase the recording time?
11 REPLIES 11
Yes... in the rules for each camera ( edit rules by clicking on pencil ) there is a slide bar for recording up to 120 seconds for each motion detect
amattiel
Thank you!
BTW, the other slide bar is SENSITIVTY even tho called "more vids - less vids"
It will take a few trial and errors to get it to record on motion all the time... angle down is best to keep sunlight/reflection of same out of motion detector ( that picks up IR change ) fiq 15-20 ft max +/-
R_Lowe
Luminary
Luminary
Two things I thought I'd chime in about, amattiel:
1.  As Tom mentions, you can set the recording up to 120 seconds. I [have 4 Arlos but] also have used two Dropcams for a year now.  I almost never need to see more than 30 seconds worth of footage (but w/Arlo, I do set it for 60 seconds).  So 10-120 seconds is a really good range to choose from.
2.  Further, even if you set your detection recording to last, say, 30 seconds, should there be additional motion at the end of the recording -- and correct me if I'm wrong anybody -- your Arlo will consider it new motion and start a new 30-second recording or whatever length you have set it to record.
All in all somebody at Netgear is using their noggin!  Cat Very Happy
mammothtarm
I just want to have Arlo record and stop when motion is detected. How do I do that. Right now it's set to 25s. I had a video this morning where someone was at my door standing and it stopped recording at 25s even though the person was still at the door.
double post in two threads, answered here too
https://community.netgear.com/t5/Motion-Detection/Recording-question/m-p/3405#U3405
mammothtarm
Sorry, thanks. I'm a NOB
Jiang
But please provide a bit more details on how to edit the "rules" in order to increase the recording length.  Thanks!
You just edit a rule and move the time slider to someplace between 10 and 120 seconds.  Be sure to save.
Iowacopper2
I am a new user and I'll be damned if I can find a "rules" section.  Dahh!
Mode tab, select system, edit your modes using the pencil icon.
