  • 2359 Views
wschimoler
Has Argo been HACKED?  I've been using the GeoFencing mode since I installed Argo several months ago. Now suddenly, the system seems to switch to AWAY mode randomly. Ramdom that is if I remain home for more than 10 minutes or so!  If I manually reconnect with ARGO and manually return to at home mode, it remains for 10 minutes or so and returns to Away Mode.  Have had to disable Argo completely to stop this behaviour.
Not hacked, but much more likely the app is malfunctioning..
Always recommend to delete and reinstall same.
Also rebooting the phone has provided fixes.
dmepperly
I am having the same problem.  It switches to away mode while I am still at home.  At first I thought it was because I always try to close the apps on my phone after using them.  I now keep this app running all the time and I still have the same issue. I rebooted the camera and I also enlarged the circle from small to medium on the home definition.  This seemed to help but it did not totally solve the issue.  I will try rebooting my phone to see if that helps.
