Geo fencing not switching
  • 14 Replies
  • 6798 Views
  • 7 Likes
  • 10 In Conversation
rabrah
I am trying to use the Geo Fencing function but it is not switching modes when it is "At Home" and using the Schedule.  The first time that it registers as "At Home" it initiates the Schedule, but then it does not follow the schedule.
For example, I came home last night, it registered that I was "At home" and it switched on the Schedule which was "disarmed".  Over night the Schedule switched the cameras to "All motion on" but then at 7:00Am when the schedule says to disarm, the cameras are still armed.
Any help would be appreciated.
14 REPLIES 14
Dana32
This is happening to me too. I wonder if it's just a glitch because get facing is new.
marcoinpb
In search for answers, many other posts on this. I have the same problem every day. Ned to manual rest every morning.
Search: Geofencing with schedules and search Geofencing with schedule (no s on schedule).
P
howarmat
yeah it looks like i am having the same issues as you all are.
marcoinpb
It may be worth noting that the necessity to restart the Arlo program every morning may be caused by your program closing the program during the night. Also, I have confirmed that that my iPhone 6+ has not rebooted during the night.
Again, Geofencing working with Scheduling does work as programed IF and only IF i manually restart the program in morning.
Koda25
I'm having the same problem, I have to manually reset it everyday! I did this the help w/my battery life and it's not helping!! When will this get fixed??
skip2753
I'm also experiencing this issue and posted here:
cameras are not accurately following schedule
At that time, I wasn't sure if it was following the schedule but just *very* slow or not at all.
I must say that I'm disappointed with Netgear's lack of information to an extremely enthusiatic and largely tech savy communtity.  Instead, we are left to speculate and try to reverse engineer their arcitechure through anadotal experiences.
For example, I would like to know how the cameras switch from one mode to another when they are using a schedule.  Is the schedule dowloaded to each cameras OS (doubtful)?  Are commands sent from Netgears datacenter to update camera mode (this is my guess)?  Is the schedule controlled from a smartphone devise?  Just knowing this would be a huge help to understand why the schedule mode is non functional.
The addition of geo fensing is a huge benefit that I believe we are all grateful for and I understand that bugs need to be irnoned out but stone walling is unacceptable.
I have forwarded these topics to the beta team for review. Geofencing is still a beta feature and will see more updates in the future.
Some users have reported refreshing their enabled devices (toggle enabled devices off, save, and then toggle back on) has helped with the issue being discussed here.
RandB
Please update when Geo Fencing is working with the schedule feature. I need the Arlo to work on a schedule but also to be armed when I leave my property. Is there another way to set this up until the Geo Fencing/Schedule glitch is worked out by tech team?
RandB,
This can be done by setting up your schedule and then within your Geofencing settings, set Home mode to "Schedule" and Away mode to "Armed". This will allow the Schedule to engage when your device is within the home location and the Armed mode to engage when you are away.
crazyaden
I am doing just this and it is not working. I am running geofencing with away mode in "armed" and home mode in "schedule.
I am using mine ad my wifes Iphone 6 (both are being tracked). But when one of use leaves or arrives, it is not responding with a change. For example, when she arrived home the system remained armed.
Jason
crazyaden,
Consider refreshing your enabled devices within Geofencing settings. Disable all listed devices, save and then enable the devices again.
Also be sure the app stays logged in and is running on both mobile devices. If the app is logged off/not running Geofencing will not work.
Do you still see the same behavior?
rabrah
Hi,
It seems like this is a 'bug', so i hope that the beta team is reviewing since this is really quite fundemental to the function i.e. auto-switiching modes.
One other thing that needs to be reviewed by the Beta team is the use of multiple devices; the system is curerntly unable to deferentiate between devices, so if I leave and my wife (and her phone) remain, Geofenching picks up on my device leaving and flips the mode.  I think that it should be and AND function and not an OR function i.e. if my phone AND my wife's phone leave the area then flip mode rather than if my phone OR my wife's phone.
Lastly, this has been in Beta for quite some time.  When is it going to be be released in a more stable, 'Alpha' state?
Thanks Arlo team
Roger
Just an FYI, alpha status is even earlier in the process than beta. Omega would be a better choice.
rabrah,
Geofencing is designed to operate on a "first in, last out basis". This means that if any device is in the Geofencing radius the "Home" mode will enable, and the "Away" mode should only enable when the last device has left the radius.
If you are having trouble with this, consider refreshing your enabled devices within Geofencing settings. Disable all listed devices, save and then enable the devices again.
Also be sure the app stays logged in, is running and location is enabled on both of your devices. If the app is logged off/not running Geofencing will not work. It sounds like the app on your wife's phone may not be running when you leave the Geofencing radius.
Geofencing is still a Beta feature at this time and the engineering team is working hard to improve it. We appreciate any and all feedback related to this feature.
