Geo fencing and armed
  • 1 Reply
  • 1212 Views
weinae1
Geofencing has not worked reliably the last two days, Siren went off for no reason, now... my geofencing has disappeared from my phone... I can manually change the setting, but there are three of us in the house, and we dont want to have to survey who is actually home each time we leave... What is going on with geofencing?
weinae1,
Geofencing is designed to operate on a "first in, last out basis". This means that if any device is in the Geofencing radius the "Home" mode will enable, and the "Away" mode should only enable when the last device has left the radius.
For this to work be sure the app stays logged in, is running and location is enabled on your devices. If the app is logged off/not running Geofencing will not work.
When using multiple devices, the secondary devices should be logged into the app via shared account through the "Grant Access" feature so that both devices are logged in using the mobile app. Take a look at this article for more information: How do I add and manage multiple mobile devices for geofencing?
If you are having trouble with this, consider refreshing your enabled devices within Geofencing settings. Disable all listed devices, save and then enable the devices again.
Geofencing is still a Beta feature at this time and the engineering team is working hard to improve it. We appreciate any and all feedback related to this feature.
