  • 4 Replies
  • 29259 Views
SteveB
I am trying to determine the easiest and quickest way to view my front door when we are home and someone rings the doorbell, so we can decide whether to answer or not. I was told by technical support to wait for an e-mail and then view. That seems too long; the person may be gone.
Thanks.
snip3rboy
Thanks.
Hi @SteveB
You can position your camera so that it detects motion and start recording as soon as a person, within range of the PIR, walks across the motion detection zone. You don't need to wait for the person to ring the doorbell.
As soon as the motion is triggered, you can get push notifications sent to your phone (iOS or Android).
You can then open the app and click [PLAY] on the camera to see who/what triggered the motion.
This article talks discusses how to optimize motion detection: How Do I Place My Arlo Camera?
SteveB
Thanks for the response. How do I activate push notifications to my phone?
snip3rboy
When you installed the iOS app, it should have prompted you to accept Push Notification from Arlo. Did you Allow that?
Here's an article on how to Allow Arlo Push Notification
Don_U
I have been stunned by the speed of notifications, but for what you are trying to do, I don't think an Arlo camera is the best solution.
However, any other option with a remote viewing screen that's not attached to the wall right inside the front door, is going to require some hardwiring.
You could give Arlo a try and see if it's satisfactory. Find out what the returns policy is from where ever you purchase first.
Good luck.
