Creating Modes?
  • 1 Reply
  • 11429 Views
  • 1 In Conversation
ssterling1912
I'm trying to set up the motion detection for the cameras. For some reason, when I go to settings and modes and try to add one by clicking the plus sign in the right top corner, it does nothing. The plus sign is actually grayed out. I have added new rules for motion and did that just fine, but can't figure out how to set up modes. From the main menu, before clicking on settings, if I scroll over to modes, it just just continuously load, and never finish. If I push th e back button on my phone, it shows my base, and when I click it just goes back to loading. I have updated the firmware and now running the most recent ones. How do I get my modes working. Please Help!!
ssterling1912
---UPDATE---
I was finally able to get it working after resetting the entire system. I deleted each camera from the system first. The. Deactivated the base. Unplugged, then repluged base. Turned it back on, and resynced all the cameras. Finally I was able to use modes.
