Changing subscription
  • 9 Replies
  • 11273 Views
  • 5 In Conversation
Joshday81
I am attempting to upgrade my subscription, but I can not see the option in the app.  I was told to go to settings then subscription, but I do not see a link anywhere under subscription.  Any ideas what is wrong?  All I see is that I have basic, but I do not see prices or their plans anywhere as others have described.
9 REPLIES 9
Where are you and/or set up the system?  There's a limited number of countires where the additional subscriptions are available - perhaps you're not in that list.
https://community.netgear.com/t5/Arlo-Knowledge-Base/What-are-the-available-Arlo-subscription-plans-...
Joshday81,
Adding to the comment above, take a look here for instructions on how to change your subscription plan: How do I change or cancel my Arlo subscription plan?
Frank1089
I'm having the same issue, I've bought my arlo q, installed it, and didn't setup the cvr at first. But now I want to, and I've been on every blog created and followed every steps.. I go to setting>subscription> and from there the only thing you can press on the screen is Manage camera status. From there all I can do is slide it into active or inactive... that is all 😞
There's no "edit account" or upgrade now as stated by everybody... I'm stumped..
Might be a country thing - where are you? Also, are you using the app or a browser? Have you tried the other?
You don't see this?
https://www.dropbox.com/s/8kbi7j1gi68lxa3/subs.jpg?dl=0
jimhammer1
I have the same issue. I want to go from "basic" to annual. The app tell me to login at the web site to change it. Doesn't provide a link. I am in the USA.
Not sure about the exact steps here but maybe it's an issue of whether it's iOS or Android.  Have you used a browser to attempt this?
jimhammer1
Finally figured how to do it. Must login on a computer instead.
jimhammer1
Arlo is devicist.
jimhammer1
All my devices are Apple. Arlo is working well on all of them.
