  • 6 Replies
  • 2556 Views
waynestractor69
I am trying to set the sensitivity and Zone but there is no option for saving the changes. I have to say the menus really do suck, and the manual is not much help!
That's what I use, too. However, there is no "back arrow upper right". I think you're using the browser back arrow which, unless you've reconfigured the browser interface, is on the upper left. In any event, DON'T use the browser back - use the Back selection at the left of the Motion Settings header in the displayed page. You will then see the Save button is available.
6 REPLIES 6
With adjusting the sense level, you must edit the Mode....
when you edit and adjust the sense level,use the BACK at top left of page, as the SAVE is at the bottom of previous page
waynestractor69
This is what I am trying and it won't work...
Mode
For that camera I click the arrow on right
Under Rules I click Edit for Push Notifications
Click Motion is detected arrow on right
Make adjustments
Back Arrow upper right takes me back to Edit mode
Second back arrow sometimes takes me to blank screen, other times to Set rules page, regardless the save button is always grey and does nothing.
What device/OS?  I just tried this on both a browser and Android app which work differently from each other as well as what you describe.
waynestractor69
I am on Windows 10 using Chrome.
waynestractor69
That was it! I was using the browser back button as I had never notice the one you mentioned. Thanks!!
