  • 4 Replies
  • 2600 Views
milly54
I moved, didn't realize I should have set my cameras to offline. But I've set them up in my new place, was getting notifications and then the notifications quit. When I go into my settings for my base station there are no choices to adjust anything but time zone, flicker adjustment and them it gives the fw version, hw version and xcloud it.
There are no settings!  Can anyone help?
Thank you so much
Try and reboot the base vai the power button...
If that doesn't work, you may have to REMOVE the camera and bring back as new and resync also;
SETTINGS > pick camera > REMOVE DEVICE (bottom of page )
trickytcamgeek
Luminary
Luminary
Maybe the problem is you have two email accounts.  See here:https://community.netgear.com/t5/Arlo-Apps/Cameras-Not-Showing-In-Mode-Page/td-p/1114865
milly54
Thanks, but no...I only have one email for Arlo.
milly54
I was thinking of doing that...just thought I'd check to make sure I'd dotted all my i s and crossed all my ts 🙂
