  • 2 Replies
  • 1161 Views
monifa71
I noticed that the camera does not record motion for up to a half hour at certain times of the day. For example, it will record at 7:29am and then not record motion again until 8:01am.
Is there a schedule set and active? If so, check your times for any mode at those times.
Schorschi
Prodigy
Prodigy
You may also want to inspect the "armed" indicator for the camera during that apparent outage period. Is it black (armed) or grey (disarmed)? If grey, the camera is not programmed to sense motion.
The "armed" indicator is the Running Man symbol above the camera view on the camera page.
Check out the FAQ
to see what the icons look like.
Scroll down a bit to the table of icons and note the icons labeled "Motion is armed" and "Motion is disarmed".
