Brightness
  • 4 Replies
  • 2766 Views
nicholshornlake
Luminary
Luminary
Is there a way to save the brightness setting on a camera?
Just tried playing with my camera and realized that you select the brightness control icon, set the brightness and then select the brightness icon again to save.  You should see a "Brightness Saved" message at the top of the live view. Were you missing that last step?
You set the brightness by live viewing and using the half white, half black sun thingie. Once set, it's saved.
nicholshornlake
Luminary
Luminary
I did that, but when I go back and check it is again on full brightness.
nicholshornlake
Luminary
Luminary
Yes, thank you. I was missing the last step.
