Armed vs all motion on? Witch one is a better setting
  • 2147 Views
Hanson913
I'm a new owner of the arlo just checking what setting is better? Thanks
Schorschi
Prodigy
Prodigy
Should be practically identical. “All motion on“ is from the pre-December firmware update and shouldn't even exist any more. It might actually disappear if you do a hard reset on the base station, which is induced by holding down the recessed reset button for 20 seconds.
Hanson913
 Well I have to re-sync my cameras if I do the reset?
Schorschi
Prodigy
Prodigy
Yes. For the hard reset you do.
