  • 1690 Views
DoggonePretty
Hi,
I am needing the cameras to detect motion after business hours and push an email to me when detected. It is set up to record for one minute.
I do not need the cameras to detect motion during daytime hours but I do need them to record. I read where you can set them to a 24 hr record but only to record when motion is detected.
I need them to record from 7:00 AM to 7:00 PM, Monday through Saturday.
How exactly do I do this?
Thanks!
Hula_Rock
Prodigy Prodigy
Prodigy
DoggonePretty wrote:
Hi,
Thanks!
This "system" will not fufill your requirments (It can be done, but you will be replacing the batteries everyday)
DoggonePretty
Well...I was afraid of that.
Thanks for the reply!
If the cameras are to be inside, you may be better off with the Q cameras which are AC powered... no battery limitations and they will record at any motion.
Each camera would have it own schedule and if you created custom Modes for each cam it will do what you want as per notifications
Only down side to the above is if you want 24/7 record review... then you would have to purchase the CVR option that Netgear offers.
