Arlo base station cant be found on Android
For two weeks my Arlo has not worked. Figured it may be my internet but nope. Tried setting it up a few places and nothing. The arlo base station just isnt detecting with the app. I can see the red lights on arlo when i move it which indicates its working and connected but the app is not working.
Message 1 of 2
1,217
Uruwashii,
What is the behavior of the LEDs on the base station? Is the internet LED solid green indicating the base is connected to the internet?
Consider a reboot of the base station and check your app again. Also consider checking using a different device (such as a PC via the web client) to further isolate the issue.
Message 2 of 2
1,209
Android App
Geo-Fencing
89 -
iOS App
Online Web
Surveillance
