Arlo base station cant be found on Android
  • 1 Reply
  • 1247 Views
Uruwashii
For two weeks my Arlo has not worked. Figured it may be my internet but nope. Tried setting it up a few places and nothing. The arlo base station just isnt detecting with the app. I can see the red lights on arlo when i move it which indicates its working and connected but the app is not working.
Uruwashii,
What is the behavior of the LEDs on the base station? Is the internet LED solid green indicating the base is connected to the internet?
Consider a reboot of the base station and check your app again. Also consider checking using a different device (such as a PC via the web client) to further isolate the issue.
