  • 5 Replies
  • 2965 Views
Rufaro
I want to set the schedule for the cameras to arm at 23:00 and disarm at 7:00, seven days per week, but it won't let me do this because it says "Start time should be earlier than stop time".
Two segments. 2300-2359, then 0000-0700.
5 REPLIES 5
Rufaro
Thanks!  I didn't realise you could create additional schedule segments
The schedule does not go thru midnight...guess it's the easy way not to worry about date changes.
MaryGarrett12
I think I may be getting the hang of scheduling my cameras ????? Do I have to click on each camera then on each day of the week, or is there a way to put the same schedule on all 4 cameras ? I want on at 10pm and off at 5 am. I do understand about the off at 11:59 and back on at 12am.
Thanks so much
Mary
If I understand you correctly, you need to create a new mode (or edit an existing one) so that it contains a rule for each camera.  That is, the mode will contain 4 rules.  The first time you create a mode, you can only set up a rule for one camera.  Save it and then reedit it to add an additional rule for another camera.  Save and reedit, etc., etc. until you're done.  Now you can schedule that mode as you desire.
