Arlo WireFree Motion Detection Too Sensitive
  • 1 Reply
  • 1873 Views
gcodd
I recently purchased an Arlo WireFree camera and mounted it in my basement to monitor a wide shot showing wall with (3) windows and (1) door which also has a window.  I have the sensitivity in the motion sensitibity setting in the "Rules" section of the app turned all the way down to 1% and I am still receiving false triggers from the camera?
I'm not sure what else I can do except move the camera, which defeats the purpose of having it as I want to monitor that specific potential point of entry into my home when I am away.  In the past :30 the camera has detected motion 20x....sometimes 2x within the same minute?
Is there something wrong with this camera?
Sounds like maybe....
Open and close the battery door to reset camera just in case. ( do near base so it auto resync's )
 Take the camera and move it to a location that faces a wall about a foot away and see if you still get false triggers. ( at default setting of 80% )
If so, then contact netgear as it may be a troubled cam.
If not, test again back in the prev location.
OR if you have two cams, you can always swap the 2 and see if the problem follows the camera ( or is location )
