Arlo-Q audio sound is too weak on Android Phone.
I'm using Arlo-Q. the 2 way audio is works well when I test it on my laptop. but there is problem on Android phone.
When I turn on the mic on the Arlo app, then the sound volume is too weak. If I turn off the mic, then it's back to normal.
Message 1 of 2
1,590
horim80,
You will only be able to hear sound when using the live view when the mic is off. For more information take a look at this article: What is Arlo Q’s push-to-talk feature and how does it work?
Message 2 of 2
1,577
Android App
Geo-Fencing
89 -
iOS App
Online Web
Surveillance
