Hi
I purchase 4 arlo pro camera.
When I'm home. I still want the garage and the front door camera to stay active the rest don't need. How can I do that?
I do have smartthing and have it connected to it.
Thanks!
Thanks!
Message 1 of 4
876
Go into Mode, click on your base station, at the bottom click (Add a Mode). Create a new model and add those 2 cameras to it then you can set the schedule to have that mode active during the day and all motion on at night. Hope that helps
Message 2 of 4
863
Hi,
thanks for your reply.
I was more looking for this kind of setup:
1) Mode set to GeoFence
2) when get Home, only Living room camera will get disable. The rest will stay enable.
3) When reach certain hour at night when sleeping, all camera will be enable.
Anyways to use this methode? Or maybe smartthing can do this? or IFTT?
Thanks!
Message 3 of 4
849
Arlopro123 wrote:I was more looking for this kind of setup:
No problem with #1
#2 manual mode or possible IFTTT
#3 use schedule for mode
Message 4 of 4
836
Android App
Geo-Fencing
89 -
iOS App
Online Web
Surveillance
