Android Arlo App: Library gets stuck showing one Camera at a time.
  • 2 Replies
  • 17170 Views
StuBee
Luminary
Luminary
You can duplicate this one..so should be easy for them to fix...Fairly minor, but confusing if you don't know what's going on.
- Launch Arlo app on android phone
- Go to Cameras tab
- Choose the Green Box number in the top left of one of the camera views....it will take you to the library of just that one camera.
All is fine so far...
- Now go back to the Cameras or Library tab.  You will not be able to get the combined library view of all activity from all cameras again.
If you do want to view all Cameras library again, you have to sign out and sign back in the app.
FedericaC
Hi StuBee,
There is a 'Filter' button on the right side of the app, which allows you to flip between cameras and see the library for each camera.
You can also check that your Arlo Android app is running the 1.9.0 version. This information is available in Google Play.
Please let us know if you can now see the library of all cameras.
Best Regards,
Federica
FedericaC
Hi StuBee,
Best Regards,
Federica
StuBee
Luminary
Luminary
Not sure how I missed that...thanks!
