  • 2 Replies
  • 3473 Views
Matej
I would like to ask you if you think about new feature for batteries Arlo. My idea is create plugin hardware instead batteries which will use power adaptor and update firmware for 24/7 monitoring. I think it should be easy. Maybe you can get new customers which need 24/7 monitoring and current batteries solution is not suitable because of batteries "life". I am satisfied with Arlo, no freezing and other common camera problems. I have power socket near to Arlo and I would like to use 24/7 monitoring with no batteries change. These batteries are not standard and are little bit expensive.
Have a nice day
Matej
Matej,
Consider taking a look at the Arlo Q, which is a wired camera option. Take a look here to see the Arlo Q compared to the Arlo Wire-free system: Arlo Wire-Free compared to Arlo Q
Matej
but this is for outside use, Arlo Q is for indoor use.
  • 2 Replies
  • 3473 Views
