  • 2 Replies
  • 1581 Views
s1
what is the best options for the batteries? i am using duracell dl 123A ultra 3v. i have a 24/7 gym that i use them at and they only last for a little over 2 weeks before i need to replace them. what would be the best rechargeable battery i could use? thanks
You can get the OEM cells online for about $1 to 1.50 depending on brand...  your usage must be fairly heavy to get only 2 weeks.
As to the rechargeables... read this thread;
https://community.netgear.com/t5/Buying-Options-Tips/Rechargeable-batteries-for-use-with-Arlo-camera...
about 21 pages, but you can prob skip to near the end...
At last look, the nightcore and eagletec seemed to be the better batteries for heavy usaage... the site and charger is in the thread..
Be aware tho you may have to change sooner because the high use... but the good thing is a few testers found rechargeables to work better for heavy usage vs long time low usage.
s1
Thanks for the info much appreciated
  • 2 Replies
  • 1582 Views
