  • 2 Replies
  • 874 Views
theberber
I have an Arlo system at my home address. Is it possible to link cameras from my business address on the same network? It not that I am trying to save on buying another base station but monitoring from the same account would be easier.?
Not sure what you mean by the "same network" - are your home and business running on the same network?
You can have two systems on separate email addresses and view them on one login by using Grant Access for one system to the other email address.  That address/login will then show all cameras. Is that what you're after?
If you have one account, but two bases ( or more ) you can run them at two or more locations under the same account... the limit is for your service level ie; the number of cameras... free=5, next $=10, next $ is 15.  ( cameras are your limiting factor, not the bases )
The bases MUST be within wifi distance of a max of 300 ft or less to connect to the cameras.
  • 2 Replies
  • 875 Views
