Will this model (VMA1100-10000S operate with BT HUB 3?
  • 5 Replies
  • 2984 Views
  • 3 Likes
Moon_Upstairs
As per subject - I read in a review that this unit does not work with BT Hub 3, but the review is a year old. Is this still the case, or is the review inaccurate?
Based on user comments here, you need to have your ISP upgrade your device to a BT Hub 5.
5 REPLIES 5
Geoff
Luminary
Luminary
I am running a Homehub 4
I stand corrected.
Moon_Upstairs,
The BT Homehub 3 is known to be problematic. There are settings within the device that cannot be changed that do not allow Arlo to be function correctly. Many users however have reported that they do not have this issue when using the BT Homehub 4 or 5. As suggested by jguerdat, consider contacting your ISP to upgrade if you are experiencing issues using the BT Homehub 3.
Moon_Upstairs
Thanks to all for very helpful replies - much appreciated.
  • 5 Replies
  • 2985 Views
  • 3 Likes
