- English
- Arlo Forum Discussions
- Buying Tips
- Re: Will VueZone mounts (such as the table mount) ...
Message 1 of 2
13,299
The Vuezone half metal ball system was the same I received in my very early Arlo beta packge... The mounts were the same.
Since the magnet attachment method is the same , I see no reason it wouldn't work.
One note tho, If the mount is on a wall make sure the mount is secure as the new Arlo cameras are heavier.
FYI; I use some of my old vuezone wall mounts for the Arlo cams without problems.
