  • 7 Replies
  • 29370 Views
  • 2 Likes
  • 5 In Conversation
Anthonytan933
Does it work in 200voltage?
7 REPLIES 7
Don't know if supplied transformers for other counties are for 220v, but in the US 110v to 12v dc output via coaxal plug.
User1
Hello,
Could you please send me a picture of the home base's DC transformer adaptor?
I need to buy a transformer if I purchase this product from the US. It would help he.
Thanks in advance!
Schorschi
Prodigy
Prodigy
I believe that's it right above/before your post. If you can't see the image, it says:
Input: 100-120V ~50/60Hz 0.56A
Output: 12V (DC) 1.5A (center pin is positive)
User1
Hello and thank you for answering!
The image above captured from the home base itself.
What I want is to see the actual cord and its transformer.
I would appreciate it if someone could send me a picture of it.
Thanks!
Thanks!
The US version has a standard 2 prong plug ( for US ) ..the output end is a coaxial plug, center +, looks like 5 or 5.5mm dia
Ellam
Would this work on 220 v?
There are more threads re this... but the US version uses a wall transformer at 110v ac to output 12dc at 1.5a
So, the base runs on DC with a center positive coaxial plug.  A 12dc source from yr 220v system should work fine.
  • 7 Replies
  • 29371 Views
  • 2 Likes
  • 5 In Conversation
