  • 5 Replies
  • 1307 Views
CaptAhab
I am using an Arlo set up to monitor security in a property that I manage with feeds to my I-phone. No problems with this set up, its runs perfectly.
But, I'm considering putting another 2 systems into another 2 houses, and would like to know if I could monitor three different independant systems via the app on my phone. (and if so how?.)
Regards
Allan
5 REPLIES 5
Regards
Allan
Allan...
Yes it can be done easily...
1) increase the service level you have to cover the number of cameras wanted above basic ( 5 )... next 2 levels are (10 and 15 ).
There is no limit to number of bases. All cameras would appear under the same account. ( max 15 cams on one account )
2) set up 3 basic level accounts using different PWs and User names ( up to 5 cams each ). You would have to log in/out each account separate.
Only other note is if you use the Q cam with the paid CVR option , then they don't count against the total #
Schorschi
Prodigy
Prodigy
Only thing to add to the above, in case it isn't clear: 1 and 2 are two alternative options. With 1 you have to pay a subscription fee. With 2 you don't, but you have the hassle of having to continually log off and on your three (free) accounts.
Slight modifcation here, too - if you add access to the cameras on the other systems using the email address on the main account you can see all the cameras on one account/login.  Takes a little putzing but should work.
I take it you mean as a "friend account"
Yup.
  • 5 Replies
  • 1308 Views
