  • 2 Replies
  • 16269 Views
eman
I see they have power pole and other adapters but it still looks like 300ft range. I have a wearhouse and i need some cameras about 900ft plus away from base station. any help to insure i get full corvage range?
Nhellie
Virtuoso
Virtuoso
As of now, the best practice would be to place the base station on a location where it is in line of sight of the cameras (I think that will get you full coverage since there are no interference). If you have swicthes all over the warehouse, you can plug a base station on each.
adding this for reference:
https://community.netgear.com/t5/Arlo-Knowledge-Base/How-can-I-increase-the-range-of-my-Arlo-system/...
JPC
Prodigy
Prodigy
Since the camera is limited to 300ft range & dependent to the base station.. There's really nothing you can do to increase that.. Assuming that you gonna' use only 1 Base Station, some of those cameras that you said need to be away 900ft from the base will definitely not gonna get the range.. Now if you plan to put more than 1 Base stations then you gonna' have to find a way to put those Base stations within range to the cameras..You can prolly' use Range Extenders to move the base station closer to the cameras but throughput may fluctuate due to interference and other devices connected to it.. Or run cables from router to base, then it'll be fine..
  • 2 Replies
  • 16270 Views
