  • 8 Replies
  • 18423 Views
purpleiris
Hi
I am from Canada and wish to purchase your products. Is there away to purchase your products and when will your products be available in Canada?
8 REPLIES 8
They may be available now... at least the pricing schedule is.
https://community.netgear.com/t5/Arlo-Knowledge-Base/What-are-the-available-Arlo-subscription-plans-...
JennC
Hi Purpleiris,
Currently, Arlo is available in the US  and some countries in Europe and Australia. However, Arlo can be brought and used worldwide. It is just that you will not be able to upgrade your Arlo system to a paid service level (Premier or Elite), just the basic plan in Canada.
To know more about the paid service, please see link below:
The same topic was also discussed at:
https://community.netgear.com/t5/Buying-Options-Tips/Will-Arlo-be-available-outside-the-US/m-p/183#U...
Regards,
JennC
NETGEAR Community Team
purpleiris
So are saying i can buy from your website in the us the hardware, and get a simple plan?
JennC
Hello Purpleiris,
Yes, you may purchase the hardware from authorized resellers.
The defaut subscription is Basic plan which allows you to have 1 base station, max of 5 cameras and a 1GB could storage.
Regards,
JennC
purpleiris
Wow, 1GB is really not much space for a 24 hour camera system>
Any word on when the full service will be available in Canada to increase service and suppoirt for the products on the website for Canada?
So far there are no retailors suppling your prodiucts and we need to be able to purchase these through a canadian website at our pricing at current curency exchange rates.
Your system looks good and portable, I need this system to be reilable for a nieghbour harassment situation.
RobertRosal
Virtuoso
Virtuoso
You have to remember, this system is not meant to stream or record 24/7, only on movement.
-Robert
It's NOT a 24/7 type of record system....
1) it MOTION based which means it will record from 10 sec to 120 secs ( adjustable by user ) when it detects motion
2) 10 seconds of video is about 1 mb, so your looking at about 1000 - 10 second clips... you'll prob never fill the 1gb with normal use.
3) with the basic plan, after 1 week the older vids will be removed to the recycle bin automaticly ( where they stay another week+ and don't count toward your total ) OR you can set it so when usage is max'ed it stops recording OR replaces oldest first
4) you can d/l to local any vids you want to save.
JennC
Hello Purpleiris,
RobertRosal and TomMac are right. Arlo cameras spend most of their time in power-saving stand-by mode. See article below:
Do Arlo cameras record 24/7?
https://community.netgear.com/t5/Arlo-Knowledge-Base/Do-Arlo-cameras-record-24-7/ta-p/301
There is no ETA yet when it will be launched in Canada. On the Worldwide pricing below, you will see the pricing for Canada.
* At launch, some regions may only have the basic plans available. Premier and Elite plans will be activated soon after the launch. Once activated, users will be able to upgrade from the free basic plan to a Premier or Elite plan.
regards,
JennC
  • 8 Replies
  • 18424 Views
