Base station required?
  • 2 Replies
  • 10052 Views
fburnham
Is the base station required or will a pre-exisating wireless network be sufficient to manage the cameras?
A base station is always needed. While the cameras use WiFi to communicate, it's only to a dedicated base station. Any other wifi, such as from a router is of no use. The base station must use Ethernet to communicate to the Internet and, hence, withe the Arlo servers.
R_Lowe
Luminary
Luminary
From my limited technical understanding, I believe it also acts as a dedicated helper for the cameras and your system, relieving your router of any extra bandwith load.  And lastly, it's fairly smallish and unobtrusive (or about the size of a piece of paper only a bit thicker.
  • 2 Replies
  • 10053 Views
