Arlo mount options
  • 2 Replies
  • 1806 Views
hamifrew
Theft proof mount?
hamifrew wrote:
Theft proof mount?
You can use any normal threaded mount design for a camera or also Netgear has a couple of mounts. ( there is a standard threaded hole in arlo )
A mount with a little bit of lock-tight or security screws would prob do fine... BTW, it shold be mounted out of reach as with any normal camera.
( as a ps ... it been a year now and I don't believe anyones cam has been stolen yet )
Also, bear in mind that you have to be able to change batteries.  Loctite and some mounting devices may make that hard to do.
  • 2 Replies
  • 1807 Views
