Arlo iPhone update
  • 1 Reply
  • 8315 Views
  • 2 Likes
Mrs_P
I use my Arlo system solely through my iPhone/ iPad. Think we need an update where you can alternate between which cameras have motion sensors on and off. We also need an easier way to schedule the cameras, maybe a copy and paste function.
My cameras are so sensitive they pick up the grass moving when it is windy, which can be a bit too much sometimes.
It does take a bit of trial and error to cut down on the false alarms...
The two things that seem to make the easiest setup 1) angle the camera down to eliminate the reflection of IR from bushes/trees/moving cars  2) adjust the sensitivity to still capture subject but not as much false detects.
  • 1 Reply
  • 8316 Views
  • 2 Likes
