wrong notifications again
I had to remove and add the camera (ultra, no base) back. I limited active area and set Smart Notifications to Person only.
Non the less the camera reports about vehicle movements, do not know about the otheres.
How can I limit the camera reports to Person only?
We are currently looking into the behavior you are experiencing. We will provide an update as soon as possible.
A7D51B7XA0E47
you have to fix your web site. It doesn't work with mozilla firefox!
What doesn't work???
I cannot not post my reply.
The message says something about invalid HTML tag.
for some reason it works now
So you are no longer seeing the same behavior with notifications? Or did you have two separate things going on?
still see vehicle notifications
Vehicles produce heat, so the camera may still pick up vehicles due to this.
