wireless arlo camera won't sync one of three cameras
I've got two out of three cameras syncd to base and working fine, the third gives a blue slow light then goes amber, I've repeated steps many attemps. No luck on the last camera? How do I clear problem up to get it working?
Sometimes a reboot of the base and/ or camera will help.
Reboot the base via the power button, give it a few mins to come fully back
Open the battery door of camera and check batteries, close ( resets camera )
Do a QUICK push on the base sync button, then a sec or two later the camera button
***Manuals say 2 sec push, but many have found this to be much to long...QUICK PUSH works more often ****
