where in settings do you go to change viedo timing? how long the camera takes the picture for?
How do I adjust Arlo video recording length?
You can personalize your Arlo cameras to record videos from approximately 10 to 120 seconds long. On Arlo Pro Wire-Free, Arlo Q, and Arlo Q Plus cameras, you can also set your camera to record until motion stops, up to 300 seconds (5 minutes).
To adjust Arlo video recording length:
- Launch the Arlo app or log in to your Arlo account at arlo.netgear.com.
- Tap or click Mode.
- Select the base station or camera that you want to adjust.
- Tap the pencil icon or click > next to the mode for which you want to edit recording length.
Note: You cannot adjust recording length for Disarmed or Schedule modes, only for active modes such as Armed. - Tap the pencil icon or click > next to the rule that you want to edit.
If the mode only has one rule, it is preselected. - Tap the pencil icon or click > next to Record Video.
Note: If Record Video is not selected, you cannot edit recording length. - Select Record until activity stops (up to 300 sec) or select Record for a fixed length of time and move the slider to your preferred recording length.
- Tap < Edit Rule or click Back.
- Tap Done or click Save.
Your recording length is updated.
Thank you for providing those key details! (Can't change the setting if not in armed mode!) I saw previous solutions that said nothing about that - I was trying to edit while in Schedule mode. Also can't change it if the system detects motion. I know it's a pain for seasoned users, but good tech supports provides those little known details for those of us just getting started. I have to say I'm impressed with the Community support as I've always found the answers I need -- even if I may need to find a couple of solutions in order to find one with all the details! ![]()
There's a ton of FAQs here for the reading.
