whats going on?
  • 2 Replies
  • 3389 Views
feelingsafenow
Camera has blue ,green or gray screens instead of video.Also the camera takes video and instead of  fluid (moving) video it has a freeze frame video.I'M placing the camera around 20 feet from base and using a basic router.Any help apprecaited.
Try and remove camera by SETTINGS>REMOVE DEVICE
Then open and close the battery door ( check batteries )
Bring back as new and retest
feelingsafenow,
Adding to the suggestion above, the symptoms you describe often are due to WiFi interference. Consider relocating your base station and/or camera closer together, limiting (as much as possible) the proximity of other wireless devices. Do you still see the same behavior?
