I want to use ARLO thru a window to monitor the outside ,
  • 2 Replies
  • 2638 Views
EDDYK
I am having troble with ARLO , dedecting motion when unit is mounted inside facing thru window to monitor the outside any suggestions ,,,, other than mounting outside ? i want to be able to move camera to different windows to monitor outside thanks
The Arlo and Arlo PRO models DO NOT work thru windows... he sensor relies on IR detection to trigger recordings and glass blocks most IR.
If you need an inside camera that does work thru windows, you should be looking at the Arlo Q camera.
EDDYK
Thank You !!
